Bushido Blade Katana
Started by TpwUK, February 18, 2013, 09:51:33 AM
TpwUK
One of my design buddies on GrabCAD, Hans de Ridder, came up with this model over the weekend, so I decided to give it a go with KeyShot to see if i could come up with a Bushido blade using nothing other than what's provided in KS, what do you guys think ?
Martin Spencer-Ford
Josh3D
Not too bad! Lots of materials here though. May try using one wood material for all as it would give the scene and objects a more cohesive feel.
TpwUK
Yeah i tried doing that too, but the wood patterns don't seem to marry up very well and the furniture then looks too heavy in the scene, as if it's central to the attention rather than the sword, I will try again and see what i can achieve
TpwUK
Updated version, tweaked the materials on the handle and the wood type used ... I think it's looking better, less messy, as always, what do you guys think ?
Mikle
Seems like the thing holding the Katana is hovering over the Table.
PhilippeV8
Quote from: Mikle on February 20, 2013, 04:31:10 AM
Light as a feather, stiff as a board  ;) :o :-X
TpwUK
@Mikie, yes it is hovering over the table. I don't have anything that will edit the SW file and because it's multiple faces in KS as with the sword, KS wont let me move them as multiply selected objects so I tried to get the angle to look as if the side supports went through the base to act as legs. The idea was just to try and reproduce a Bushido blade effect.
PhilippeV8
Can't you duplicate the entire scene in KS, then in 1 delete all that's floating and in the other delete all that's not.  After that you can move either one around separately.
TpwUK
I dont know, I have not tried that way, let me just check I understand you rightly ...
Open scene file, select the sword and the stand, copy duplicate them and then delete the original one, the duplicate set can then be moved as a block ?
TpwUK
Ah ha, selected all the faces that were needed, right click, where is duplicate ... Hmmm not there, but MOVE is, yay - sorted!!
New render coming shortly ...
TpwUK
Ok ... Thanks for the tip PhilippeV8, New render with a better camera angle now it's not floating on Chi
