Iron Man rendering
Started by Shaun_Snow, May 19, 2017, 02:33:27 AM
Shaun_Snow
Hi everybody, I'm Shaun.
I like superhero,so I rendered one.
Please give me some advice,thank you very much.
(PS:My English is poor,I use Google Translate)
Josh3D
Hi Shaun, welcome! I think you are off to a great start. The texture may be a little heavy though. I would suggest starting off with a light texture, building up to  desired look. Really depends on the story behind it too.
NM-92
Hello Shaun. I agree with Josh on the texture being a little heavy. I'd remove the one on the eyes too, and try some different lighting environments to see which one fits best. I did try to render an Iron Man model before, and i shared a screen of the material graph if you want to take a look. Here's the link to the topic (page 11), hope it helps:
https://www.keyshot.com/forum/index.php?topic=12557.150
Shaun_Snow
Quote from: Josh Mings on May 22, 2017, 09:47:54 AM
Thank you so much for your suggestion,I will make adjustments to my renderings,hope to continue to get your attention in the future
Shaun_Snow
Quote from: NM-92 on May 22, 2017, 01:21:48 PM
Thank you for your reply,Your work is so cool!I look forward to continuing to learn from you,and hope to get your guidance,Thanks again.
