KeyShot v. 3.2.62
Started by fario, June 26, 2012, 06:58:07 AM
fario
Hello,
In KeyShot v. 3.2.62, has a registration bug when editing images and hdri environments.
The changes are not saved correctly to the .bip file.
The hdri image is not properly published in the palette Library / Environment /
Thanks.
Antoine
Bruno F
Hello Antoine,
Have you tried saving the modified hdr environment file manually?  To do this go to Project>>Environment>>Edit  (This opens the hdr editor)
You can either press Ctrl+S/Command+S or go to File>>Save to save your hdr/hdz file.  I recommend doing this right after you edit the environment in the hdr editor before closing the editor.  Should you have any difficulties feel free to contact us at support@luxion.com
Regards,
Bruno
fario
fario
ok, your solution works fine.
It might be better if the save dialog was in the range of image editing hdri, rather than the menu, ... hidden. ??
best regards.
Antoine
