Hi guys.
I working on integrating KeyShot better in the workflow of an customer and it would be a great help if is possible to have a custom .bip file open automatically when KeyShot is opened instead of the standard/default scene.
Best case, this also works when using the KeyShot plugin from within SolidWorks. Instead of opening the cad-model in the standard scene, it is imported into this custom. bip.
Is something like this possible?
I searched for a startup .bip-file to replace, but without luck. Maybe I didn't look hard enough, or maybe it works in a different way. Someone, please enlighten me :)
Best,
Esben.
Esben,
I think your looking for the Preferences to set that.
Cool, HaroldL.
Thanks, that takes me a step in the right direction.
Much appreciated.
Let's say I want to change the default brightness for the new environment that I load on startup from e.g. 1 to 2.
That is, when KeyShot is opened the environment brightness is set to 2 right from the beginning.
Is it possible to change all the default environment, lighting and camera settings when KeyShot is opened?
