Technical discussions => Data Import => Rhino => Topic started by: Robb63 on March 10, 2014, 04:29:25 PM
Title: Keyshot 4.3.18 Not Importing Rhino
Post by: Robb63 on March 10, 2014, 04:29:25 PM
I am unable to directly import Rhino 5 (and 4) files into the latest Keyshot (4.3.18). I can still mostly use the Rhino plugin to import files.
I've had some crashing (and weird things happening) this afternoon trying to update a scene with the plugin, so I thought I'd try to import the Rhino file instead. No luck!
What would be the next best file format to export out of Rhino to bring into KS? I've tried .obj and it comes in great, I just can't figure out the correct settings in Rhino to have the .obj file keep the layers, and their names intact.
I've attached the KS error screen I get when trying to import the files. BTW, I've tried several different projects, and so far I haven't been able to import any Rhino file I've tried. I've also tried several different mesh settings in Rhino. I've switched to wire frame, then "render" mode, then back to "shaded", still no dice.
Title: Re: Keyshot 4.3.18 Not Importing Rhino
Post by: thomasteger on March 10, 2014, 04:32:47 PM
Works just fine. Sounds like something went wrong with your installation when you upgraded.
Post by: Robb63 on March 10, 2014, 04:34:53 PM
Do I uninstall all of Keyshot (plugins too) then do a full install to try to fix it?
Post by: thomasteger on March 10, 2014, 04:37:19 PM
The plugins don't have anything to do with it. Yes, I suggest a complete uninstall, and then an install using the full installer.
There is a new Rhino plugin posted as well on keyshot.com/plugins. Just download and install.
Post by: Robb63 on March 10, 2014, 05:09:31 PM
I uninstalled everything, took my personal materials out, cleaned the registry, and restarted my computer. Then installed KS, pointed it to my .lic file.
The plugin is working nicely now, but the Rhino file will still not import! I even tried importing it into a new scene, thinking maybe something in the scene I was using might be an issue.
I also just tried importing some older Rhino files that I used a few months ago for some renderings. They won't import either.
I can use the plugin now; so I can get past my issue and deliver my project this evening, but I'd definitely like to get this figured out
Post by: thomasteger on March 11, 2014, 05:48:49 AM
We will check into it.
Post by: thomasteger on March 11, 2014, 06:38:16 AM
Can you send us a quick example? We have been testing this extensively on both platforms and were not able to reproduce it.
Thanks,
Thomas
Post by: thomasteger on March 11, 2014, 08:05:33 AM
There is a known bug with empty layers. If the layer is empty then all the sublayers will not be imported. So in the worse case scenario if all your geometry is on sublayers, and you have one top level layer that is empty, then essentially KeyShot considers the file empty.
I hope this makes sense. Can you send us an example that doesn't work for you?
Post by: Robb63 on March 11, 2014, 10:01:57 AM
Hi Thomas,
Yep, it was the empty layers. I removed them and the file imports perfectly.
Post by: thomasteger on March 11, 2014, 10:57:17 AM
Phew - as I said this is fixed in 5.
Glad you are "up and running" again!
Post by: al_jot on March 19, 2014, 03:25:56 AM
Hi Thomas,
so when can we expect ks5?
I just wonder because we have the same problem too, and it worked fine in the previous ks versions.
It 's really annoying, with this problem, we can't import our old Rhino files with empty masterlayers. We waste a lot of time doing unnecessary workarounds after ks updates.
Maybe you integrate a downgrade button somewhere. If one has any problems with the update, you can switch to the old version easily.
I think, ks 5 will not be released in the next 2 or 3 weeks. Is there a possibility to fix this in the next 2 weeks or can you provide any downgrade files?
Thank you
A.Jantschke
Post by: thomasteger on March 19, 2014, 07:13:01 AM
We are testing the importer right now to make sure the issue is addressed. We may end up just distributing the Rhino importer itself for KeyShot 4. Stay tuned.
Post by: thomasteger on March 19, 2014, 01:55:23 PM
We have fixed this issue. An updated importer for Rhino for KeyShot 4 is available. Please contact support@luxion.com for further details.
Post by: al_jot on March 20, 2014, 04:19:28 AM
Thank you for your quick reply. I really appreciate this.
A. Jantschke
Post by: e21 on April 26, 2014, 11:31:11 AM
Hi guys, I'm having the same issue. I went to download the latest Rhino plugins but it looks like they're Windows only. Is there a way to get the latest importer for my Mac version of Keyshot 4?
My Rhino file is very large so it's been a big time waster going back and forth trying to adjust the layers.
Thanks,
E
Post by: TpwUK on April 26, 2014, 01:15:11 PM
Rhino for Mac OSx is still WIP status, so i am not surprised there is no plugin since Rhino is subject to sudden changes whilst under development. Keyshot 5 is coming soon which has better support for 3DM files
Post by: thomasteger on April 28, 2014, 05:50:37 AM
All you need to do is download 4.3.18 from our website again, and reinstall. This will address the layer issue.
Post by: rajsingh on November 18, 2015, 11:20:32 PM
Quote from: Robb63 on March 10, 2014, 04:29:25 PM
"///D/design/001.3dm"does not contain 3d geometry.
inside rhino,please select view/shaded piror to saving it.
for additional help please contact support@luxion.com???
1. open your file in keyshot
2. select IMPORT NURBS DATA  and click this option.
3. open your file successfully
