Keyshot studio render first
Started by tsunami, April 14, 2012, 03:23:40 PM
tsunami
Some renders from an strange object.
I must improve radius geometry, because some scratch takes no effect on the surface..
hm
Despot
Very nice indeed... Pass it my way and I'll really scratch it for you ;-)
Regards J
tsunami
Quote from: biomechanic on April 15, 2012, 07:51:38 AM
Regards J
Here you can find the bip scene regarding my keyshot render studio.SO could you show me how u use your scratch way on to my model?
Josh3D
Nice tsunami... what is it? :)
J should be able to scratch that up real nice for ya.
tsunami
Quote from: josh3d on April 16, 2012, 09:09:23 AM
it's a car winch component for rear wheel;I can't share it complete..
Interesting indeed. You may want to fine tune the lighting and were it hits the object. Some edges are a little blown out. I think adjustments to the height of the environment may help.
tsunami
Quote from: Thomas Teger on April 16, 2012, 03:11:19 PM
Thanks for your suggestions...but could you tell me what do u mean exactly?...adjustments to the height of the enviroment...
thanks
Open up the project tab, go to environment, and adjust the "height" parameter. It will move the environment up or down without moving the ground plane.
tsunami
Quote from: Thomas Teger on April 17, 2012, 06:22:04 AM
Ok Thomas, thanks, sorry i didn't understand what you meant, but now is ok..i'm doing correction on height parameter in to environment tab..
