If you save the file to a folder in title which contains the Cyrillic, the folder name is not displayed correctly
And if you save or rename the file to the name with the Cyrillic, then the file will not open
That should work in 2.2.45 .. no?
No, Thomas. Unicode is not working properly
(http://img849.imageshack.us/img849/2801/0403.gif) (http://img849.imageshack.us/i/0403.gif/)
Please send me a quick example with cyrillic characters.
Thanks,
Thomas
ok, one second
Thomas, сheck your personal mailbox
Got - we will check into it.
Works great on the Mac. Will check windows.
You said the file will not even open for you?
If you double-click on the file to open it doesn't seem to work. If you open it via File > Open, it works just fine.
Thank you, Thomas
I use Windows 7 [64]
The file is opened, but there is no geometry. Empty file
File name "Дельфин.bip" is changed to "Untitled.bip"
Quote from: Thomas Teger on March 04, 2011, 11:27:22 AM
This is not good
This is inconvenient
We will fix it.
