Has anyone used network rendering successfully? Its not covered in the latest documentation. Any help would be appreciated regarding how the server / slave relationship is set up. Thanks!
-josh
We do have a number of customers using network rendering, but we are not by default exposing the feature in KeyShot as we plan to completely rework it for KeyShot 2.2. If you want to use it now please contact support@luxion.com.
I want in on this, but support didn't answer my email -
We are testing it right now.
Will you have to have multiple versions of Keyshot to make this happen, or will you just be allowed to use the processing power of other machines on you network?
I am running Pro, but would like to do this for larger renders (like most), but being a one man operation it may be prohibitively expensive if I'll have to buy another Pro seat or something similar.
Thanks,
Rob
I think it'd be best if you'd work on implementing at least an embarrassingly parallel distributed rendering platform and help out those who'd like to create animations.
Quote from: Robb63 on December 19, 2010, 11:21:33 AM
Thanks,
Rob
We can work something out. Contact us directly.
Any update on the ability to do network rendering now that you've released 2.2?
We have network rendering in 2.2 (even though we do not advertise it as it is a little tricky to setup). We do have a new network rendering system almost ready. We expect to have it available for testing shortly.
-- Henrik
