Archive => Support Archive => Topic started by: Jex on April 09, 2015, 10:09:35 AM
Title: KS keeps crashing, does not show/import models
Post by: Jex on April 09, 2015, 10:09:35 AM
Just re-installed the edu license as app kept crashing or would not import models or display examples provided (via Open).
Seems it has a problem with the (workspace) painter - how can this be remedied?
OS + KS version: see log file below
Models: step, igs + native
KeyShot 5.2.10 Log File - Thu Apr 9 19:45:20 2015
OS: Windows 7 64 bit
(19:44:13) OpenGL extension not supported: glGenFramebuffers
(19:44:13) QWidget::repaint: Recursive repaint detected
(19:44:13) QPainter::begin: A paint device can only be painted by one painter at a time.
(19:44:13) QPainter::setRenderHint: Painter must be active to set rendering hints
(19:44:13) QPainter::worldTransform: Painter not active
(19:44:13) QPainter::save: Painter not active
(19:44:13) QPainter::beginNativePainting: Painter not active
(19:44:13) QPainter::restore: Unbalanced save/restore
(19:44:13) QPainter::setWorldTransform: Painter not active
(19:44:13) QPainter::setOpacity: Painter not active
(19:44:13) QPainter::opacity: Painter not active
(19:44:13) QWidget::render: Cannot render with an inactive painter
(19:44:13) QPainter::end: Painter not active, aborted
(19:44:13) QWidget::repaint: It is dangerous to leave painters active on a widget outside of the PaintEvent
(19:44:40) QPainter::begin: A paint device can only be painted by one painter at a time.
(19:44:40) QPainter::setRenderHint: Painter must be active to set rendering hints
(19:44:40) QPainter::worldTransform: Painter not active
(19:44:40) QPainter::save: Painter not active
(19:44:40) QPainter::beginNativePainting: Painter not active
(19:44:40) QPainter::restore: Unbalanced save/restore
(19:44:40) QPainter::setWorldTransform: Painter not active
(19:44:40) QPainter::setOpacity: Painter not active
(19:44:40) QPainter::opacity: Painter not active
(19:44:40) QWidget::render: Cannot render with an inactive painter
(19:44:40) QPainter::end: Painter not active, aborted
(19:44:40) QWidget::repaint: It is dangerous to leave painters active on a widget outside of the PaintEvent
(19:44:44) QPainter::begin: A paint device can only be painted by one painter at a time.
(19:44:44) QPainter::setRenderHint: Painter must be active to set rendering hints
(19:44:44) QPainter::worldTransform: Painter not active
(19:44:44) QPainter::save: Painter not active
(19:44:44) QPainter::beginNativePainting: Painter not active
(19:44:44) QPainter::restore: Unbalanced save/restore
(19:44:44) QPainter::setWorldTransform: Painter not active
(19:44:44) QPainter::setOpacity: Painter not active
(19:44:44) QPainter::opacity: Painter not active
(19:44:44) QWidget::render: Cannot render with an inactive painter
(19:44:44) QPainter::end: Painter not active, aborted
(19:44:44) QWidget::repaint: It is dangerous to leave painters active on a widget outside of the PaintEvent
(19:44:45) QPainter::begin: A paint device can only be painted by one painter at a time.
(19:44:45) QPainter::setRenderHint: Painter must be active to set rendering hints
(19:44:45) QPainter::worldTransform: Painter not active
(19:44:45) QPainter::save: Painter not active
(19:44:45) QPainter::beginNativePainting: Painter not active
(19:44:45) QPainter::restore: Unbalanced save/restore
(19:44:45) QPainter::setWorldTransform: Painter not active
(19:44:45) QPainter::setOpacity: Painter not active
(19:44:45) QPainter::opacity: Painter not active
(19:44:45) QWidget::render: Cannot render with an inactive painter
(19:44:45) QPainter::end: Painter not active, aborted
(19:44:45) QWidget::repaint: It is dangerous to leave painters active on a widget outside of the PaintEvent
Title: Re: KS keeps crashing, does not show/import models
Post by: guest84672 on April 09, 2015, 03:05:52 PM
Sounds like a QT issue. Have you updated your graphics drivers lately?
Post by: BoatTech on April 10, 2015, 01:52:24 AM
I lost ability to use KeyShot this past Tuesday, worked just fine on Monday. After uninstall, install, and various other attempts, I finally got it running again. I opened KeyShot, and opened one of the sample files. Granted, it crashed a few times, but I just kept going back and trying it again. Then, I got this message after the last crash, and it's worked fine since then. I have a feeling it was a Windows update that messed with things, but that's just my opinion.
Post by: BoatTech on April 10, 2015, 10:05:27 AM
IT came by and looked at some settings, although I said it was working fine. Now it's not working again, crash, crash, crash.........................
Keyshot is maxing out my CPU if I use all cores. JUST sitting with a sample model, it's maxing out. I can change to half my cores, it will drop down CPU usage. Try to drop a material in, instant crash.
Post by: TpwUK on April 10, 2015, 11:46:59 AM
This sounds like a bad memory stick problem to me - If you're comfortable with running a Memtest on your computer, then do so, if not, then ask one of your IT guys to do one ...
You can get a free version of MemTest86 from here http://www.memtest86.com
Post by: guest84672 on April 10, 2015, 02:05:01 PM
And it perfectly normal that KeyShot maxes out all allocated CPU.
Post by: BoatTech on April 13, 2015, 01:45:25 AM
So, just with a model opened, it's normal for Keyshot to max out your CPU? I can see when rendering, that makes sense. But, if you're maxed just looking at a model, how are you to find the power to add/change anything? I'm not a hardware guru, so I'm probably off base here.............
Post by: guest84672 on April 13, 2015, 06:17:33 AM
With KeyShot you are always rendering - as soon as you import a model. It is fully interactive, so you can make any changes you would like.
