Since I keep running out of memory on a render, I often have to do region renders. However I would like to do those overnight. I haven't tried this yet, but is it possible to add varios region renders to the queue ??
If not, this would be a handy addition for a next version ..
Try using the .exr format. This will not hold the image in memory.
What's the ".exr format" ?
> ah I see, it's an alternative to JPEG. And why would this be any different to a JPEG render ?
Ok, from what I understand, an XP machine with 32bit can only give 2GB per program running. So KeyShot can use only 2GB during a render. If I want more, I'd need a 64bit system with vista or win7. That however is not an option here due to server compatibility. A second workstation with 64bit that is not in the server-network would be an option ... if they would let me have it :p
Now I wonder how come for a render does it use so much ram ?? Isn't it possible for KeyShot to keep an eye out on the max ram usage and before it reaches the limit, dump a jpg of what it's got so far, clear the ram and continue rendering the other part of the render and in the end either merge the jpg's or just create a second one ?
That's why you should use .EXR. It does exactly that. EXR is a 32 bit image.
How big are the renderings you are producing?
How big are the files you are using?
I render in various sizes depending on what the DTP'ers ask. But I have always 300dpi and minimal 2000 pix for the smalest dimension. For printing that's OK, but sometimes they ask for more if it's for a forex. (I don't know if "forex" is a standard used word, but here it's such a standing panel used on a trade fair). The bip file size is between 100.000kb and 170.000kb.
Again, EXR will solve your issues in this case.
