hi friends here is a interior scene which has been done recently !
Wow - first impression - Wow
second thought - Is the floor wet?
IMHO I would reduce the reflection.
BUT! great work!
Carpet hairs look a bit weird ..
And you've got some bad tesselation issues on the window and the parts behind.
Other than that .. great stuff.
Agree on the floor needing a bit of roughness to blur the reflection.
Wouldn't like to think I was stepping out of bed and on to that rug with bare feet... chances are you'd be on your way to the nearest Emergency Room with your feet dripping blood ;)
J
It is a nice image though, better than some interiors I've seen people do :)
J
thank you friends for all ur feed back and suggestions ! helps me to improvise in my work.
Wonder what happens if you duplicate the rug and rotate it 1 or 2° so that you double the amount of "hairs" ...
@ philipee
good idea but need not rotate it but can move the fur alone not the base !!!! thanks for your advise friend !!!!
Yeah, this images is a good start. Did you do any post to this? Looks like you sharpened it up a bit in photoshop or something? Otherwise, maybe it's the geometry tesselation. I'd try opening a few photo references and trying to match them. Check how surfaces appear in other photos and then edit your materials to match. I agree, carpet could look a bit softer or fuzzier. I know it's tough though. I've had trouble finding carpet models online.
Good luck!
