Archive => Support Archive => Topic started by: ksdavedude on October 12, 2015, 01:23:00 PM
Title: Keyshot 5.3.6 Floating Crashes Every time - Material Application
Post by: ksdavedude on October 12, 2015, 01:23:00 PM
We have one user who was using Keyshot fine and then suddenly he cannot apply materials to images in KS.  This does not work with default included images in the program.  It will fail immediately with this error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: keyshot5_floating.exe
Application Version: 5.1.66.0
Application Timestamp: 54928a1a
Fault Module Name: ntdll.dll
Fault Module Version: 6.1.7601.18933
Fault Module Timestamp: 55a6a196
Exception Code: c0000005
Exception Offset: 0000000000050ef7
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 3c63
Additional Information 2: 3c634ed89840ff892ebbea6fff3a2839
Additional Information 3: a803
Additional Information 4: a80332e4ba4d731c1fe0af43a6f953fc
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
It will also not allow importing.
We have uninstalled/re-installed.  Completely wiped/re-imaged computer.  Have tried updating Graphics drivers and rolling back graphics drivers.  All with no joy.
If I take him back to Version 5.0.99, the program will work fine.
We have other identical machines running the 5.3.6 software without issue.  We have other machines with different configurations running the software fine.
Given that it happens with basic Keyshot images, this seems to be an issue directly with Keyshot.
This seems to be similar to an issue reported here, but with no fix: https://www.keyshot.com/forum/index.php?topic=10307.0 (https://www.keyshot.com/forum/index.php?topic=10307.0)
We are not sure what else to try???  Any and all help would be greatly appreciated.
Thanks.
[EDIT]  Running Windows 7 64bit
Title: Re: Keyshot 5.3.6 Floating Crashes Every time - Material Application
Post by: ksdavedude on October 13, 2015, 09:25:31 AM
Keyshot found a fix.  This was running on a Dell T7810 and it seems there is some conflict with Dell Backup and Recovery software.  We do not use that, so we removed it and Keyshot now works.  Go figure....
