Archive => Support Archive => Topic started by: mariomarimba on December 28, 2015, 03:58:03 PM
Title: Curved Glazing creates Clipping to objects behind
Post by: mariomarimba on December 28, 2015, 03:58:03 PM
Hi
I am an architect .had KS-3,-4 and 5.  Never had any issue until this recent one with KS-5.
there is some strange clipping that curved glass causes to objects behind.
I model in Moi 3 and Rhino 5.
My Comp is Dell 5810 tower.
Intel(R) Xeon(R) CPU-E5-1630 v3
Graphics card Nvidia Quadro k 4200
I have tried FBX, OBJ, STEP but cliiping is allways there.
however recently i modelled a little experimental car and rendered in KS-5 and none of the above problems occur .
interestingly enough when i open the same model in KS-4 I HAVE NO PROBLEMS AT ALL.
So I am rendering at the moment my architectural models in KS -4.
I AM ON WINDOWS 7
THANKS REGARDS
Title: Re: Curved Glazing creates Clipping to objects behind
Post by: mariomarimba on January 06, 2016, 03:00:20 PM
key shot team
is there anybody who can look into this matter?
thanks
Post by: PhilippeV8 on January 08, 2016, 06:24:56 AM
Are you sure the geometry behind does not touch the glass ... even if 0.01mm sepparation between the 2 planes could maybe fix this.  Give it a try.
Post by: mariomarimba on January 08, 2016, 06:35:05 AM
philippev8
no it does not touch it at all
Post by: Speedster on January 08, 2016, 01:38:39 PM
Is the glazing "glass" single or two-sided?
Post by: mariomarimba on January 08, 2016, 03:41:54 PM
speedster
thanks for response.  Glass is not assigned as double sided.  It just had thickness of 30 mm.
however similar clippings occur on another model I can't post.  That model has no glass and clippings occur when i change perspective to 21.  it looks like large ball of nothing in the middle.  the problem is such that i have to resort back to KS 4 that works fine.  it does not show this problem with the same model imported.
thanks
Post by: PhilippeV8 on January 10, 2016, 10:54:43 PM
If you move the camera, does the clipping change ?
Post by: mariomarimba on January 11, 2016, 10:14:40 PM
I just imported model as nurbs from MOI directly and clipping has not occured.  I shall keep monitoring and posting outcomes.
thanks for all comments.
Post by: Niko Planke on January 12, 2016, 05:44:42 AM
We solved this issue via Mail.
In this case the scaling of the model was wrong.(A factor of approximately  10000 to small)
By scaling the model up to a realistic size the clipping could be avoided.
