Archive => Support Archive => Topic started by: Flavio Hilario on February 05, 2016, 06:08:18 AM
Title: KS for SolidEdge is not keeping materials from scene after Update command
Post by: Flavio Hilario on February 05, 2016, 06:08:18 AM
Hello
After setting up an entire scene imported from Solid Edge, KS is not keeping materials details on scene, after Updating the file (inside Solid Edge).
All materials get back from original state, even if we don't change shapes or faces colors inside Solid Edge.
* Solid Edge ST8 + KS 6.1.65
Title: Re: KS for SolidEdge is not keeping materials from scene after Update command
Post by: paco67 on February 11, 2016, 06:56:43 AM
I have installed the same versions, but KS keeps materials details on scene, after Updating the file (inside Solid Edge).
The main problem for me are the Solidedge animations between views: when export to KS they are completely different. I think this problem cames out when we zoon between views. Another problem is the environment color and shadows: I can't change in KS, or better if I change and use the animations previews it comes back the original.
Regards/Francesco
Post by: Flavio Hilario on February 19, 2016, 05:11:22 AM
Hello
For my case, I re-installed KS (full, not only the update) and now it seems it works properly.
Francesco, for your case, about the animations inside KS getting back to original imported from SE, I think if you save the View on the Camera tab after any changes, it will work fine.  When we hit 'play' , if your view is unsaved, KS will put all back to original again.
