Hey guys I really need help, I'm making a citric squeezer and all the elements that are on the inside of the bottle when I place a transparent plastic material appear in black, I tried to move in the advanced options but I'm a newbie and I don't know how exactly how to make the elements on the inside to appear on the material that they are supposed to be.
Hey gaboflr-
Under the Lighting tab, make sure Global Illumination is enabled, and that Indirect Bounces is set to at least 1. Also, increasing the Ray Bounces to between 10-16 (sometimes more, depending on the specific material) will yield a more realistic result with transparent materials. As a side note, it appears that your model is intersecting the ground; try moving it up in Y by a fractional amount.
Eric
Normally this is fixed by using two sided in material properties and or number of bounces in the lighting settings
Quote from: TpwUK on April 21, 2016, 06:38:02 AM
This is correct concerning the Glass material (it will even render correctly without Two-sided enabled). However- Glass (Solid), Liquid, Advanced, Dielectric, Gem, and Plastic (Transparent) materials, all need Global Illumination enabled for correct rendering, in my experience.
Eric
thank you so much guys, I couldn“t find the two sided tab or part in the advanced materials, but it was fixed just by changing the lighthning to global, it worked perfectly, I'm so grateful with you, I was ina hurry! ;)
You're very welcome...glad it helped. The Two-sided option under the Properties tab is not available for the Plastic (Transparent) or Advanced materials which you were using; it is specific to the standard Glass material.
Eric
