I downloaded some materials from internet and put them in keyshot material folder. Whem I open the Keyshot, they load the new materials but when I assign new material to the model nothing happens and in textures tab under Diffuse and Bump writes "Texure missing", see the picture:
https://www.dropbox.com/home?preview=Capture.PNG
I wasn't able to see the picture (don't have a dropbox account). Would you be able to attach it to your post (options to add image below text window).
Try placing the associated textures in the "textures" folder instead of the materials folder.
I have .mtl file and he cant be loaded as picture for texture.
I attached one material, can You chek it is ok on your program?
Works fine. Make sure all the textures get copied. The mtl file won't contain the textures. Only a kmp file will.
Sorry, I dont understand what I need to do, can you explain me? If attached material works fine at your program I dont understand while he dosent work on my.
No the attached material doesn't work. But I downloaded it from the KeyShot Cloud, and then it worked fine.
I assumes that's where you downloaded it from as well?
