Gallery => Amazing Shots => Topic started by: NM-92 on June 23, 2016, 02:21:54 PM
Title: Mercedes Benz 190 SL
Post by: NM-92 on June 23, 2016, 02:21:54 PM
Hello ! Found another model online (really can't remember where) and started with my typical front shot. I'll try practicing a little bit with back plates later. Hope you like it !
(http://i.imgur.com/UQWl2zp.jpg)
Title: Re: Mercedes Benz 190 SL
Post by: NM-92 on June 23, 2016, 04:22:47 PM
First backplate
(http://i.imgur.com/iWCqadK.jpg)
Second
(http://i.imgur.com/gtJ4LLW.jpg)
Third
(http://i.imgur.com/hG5nv1B.jpg)
Post by: SebasDesign on June 23, 2016, 10:09:56 PM
I think it would be better if (in case of the 3rd one) you modeled the studio and did the rendering there... the lighting would match flawlessly and could have a different contrast.. also you'd have full control on the lighting and camera setting
Post by: NM-92 on June 24, 2016, 04:44:59 AM
Yes,  going full 3D is often the best, i agree, but with these experiments i was trying to create the environments myself to see if i could make them match. Long way to go :P.
Post by: feher on June 24, 2016, 05:48:00 AM
Looking good, I'm really liking the second shot your very close.
Keep pushing and practicing.
Thanks for sharing. Will be fun watching you progress.
Tim
Post by: NM-92 on June 24, 2016, 09:32:02 AM
Quote from: feher on June 24, 2016, 05:48:00 AM
Tim
Tim, thank you ! It's fun to do it as well.
Quote from: Sebas_ace96 on June 23, 2016, 10:09:56 PM
I had to do this. Modeling the complete scene gives you much more control over the lighting, you were right, although using area lights generates those hot pixels that i hate so much, had to remove them in post :P.
(http://i.imgur.com/jwWWzl5.jpg)
Post by: Will Gibbons on June 24, 2016, 10:55:38 AM
Quote from: NM-92 on June 24, 2016, 09:32:02 AM
Did you try increasing material samples on the material you were seeing the pixels as well as on the light sources?
Post by: NM-92 on June 24, 2016, 11:05:38 AM
Hello Will. I do not increase the samples on each material. I render on max samples mode with about 1000 samples. "complete simulation" preset seems to help with this issue, decreasing significantly the numer of strange spots showing up. Anyway, it is nothing that post work can't solve :D .
Here is another one in colour and one variation in b&w.
(http://i.imgur.com/Wwr3Rh4.jpg)
(http://i.imgur.com/uoLG06g.jpg)
Post by: NM-92 on June 24, 2016, 11:50:02 AM
Last one, i promise.
(http://i.imgur.com/znLrfJL.jpg)
Post by: SebasDesign on June 24, 2016, 07:15:56 PM
Did you try with emmisive + interior mode? It worked for me a couple of times and no white pixels
Post by: NM-92 on June 25, 2016, 10:54:36 AM
Quote from: Sebas_ace96 on June 24, 2016, 07:15:56 PM
I've always used area lights for illumination purposes and emissive for details, like buttons or glowing pieces of geometry. I'll try it for a scene and see how it goes !
