Technical discussions => General discussion => Topic started by: jonathan13 on August 15, 2016, 01:51:17 PM
Title: Interesting ? with a PNG Image
Post by: jonathan13 on August 15, 2016, 01:51:17 PM
Hey Everyone.  I had an interesting thing happen that I cannot figure out.
I applied a .jpg as a label in KeyShot 6.  I made the .jpg in Photoshop and there is a layer in Photoshop of an icon I made in Illustrator.  I have tried both with and without that layer being rasterized.
When I use the .jpg as a label in KeyShot, the whole label shows except for the icon.
I also exported the .ai file as a .png and used it as a second label.  This was successful in the KeyShot image, but when I rendered it, it was not there.
Any idea?
Title: Re: Interesting ? with a PNG Image
Post by: Speedster on August 15, 2016, 06:04:46 PM
When you create the .png (don' use a jpeg), be sure that the alpha channel is checked or enabled, and that (in Photoshop or AI) that there is no background.  That way, in KeyShot, the background will be transparent.
Post by: jonathan13 on August 16, 2016, 04:50:42 AM
There is no problem with the background.
Even when I save the .psd as a .png, I put the label on and it doesn't show the icon I created in AI.  And when I apply the AI icon as a .png, it appears in my KeyShot image, but disappears when I render the image out.
Post by: bdesign on August 16, 2016, 07:23:38 AM
I can't reproduce your issue on my end. To clarify, is the situation that you have an vector smart object (copied from AI) layered over raster elements in Photoshop, save a copy as a .jpg., apply as a label, and then the label appears the same as if you had turned the vector smart object layer off in Photoshop before saving as a .jpg? No blank space where the AI icon should appear?
Post by: jonathan13 on August 16, 2016, 01:41:40 PM
hey bdesign
yes I have a vector smart art (.ai) in my .psd document (I placed it onto a layer, not copied, not sure if that makes a difference).  I saved my .psd as a .jpg (which I can open and see everything normally) but when I use it as a label, the smart art layer is not visible (you are correct there0.  But I have also rasterized that layer in the .psd before saving as a .jpg and it still doesn't show up in KeyShot correctly.
My second issue is that I tired to work around this by applying a second label of just the .ai file which I exported to a .png and basically move it over the first label where it should be.  Now this shows up correctly in my KeyShot image, but then I rendered that image and it again was missing.
I have since redone the whole thing and it works now but still want to figure this out, it's very odd.
