I added textures to my 3D model in Keyshot and need to export it to rhino again in order to build the physical model. Anyone knows how can I do that? When I export ZPR to keep the color and pattern, it just come out all black.
When you say "export to Rhino to build the physical model" you mean for 3D printing?
Did you set the view in Rhino to "Rendered". If not it will appear all black.
I need to build a physical model, so I need to export it and use the squish to get each surface. even a file for 3D print would be fine. I would just need the textured file in rhino from keyshot.
and yes I have it in render view
Below is the ZPR export that I'm able to successfully import to Rhino. Just to be clear, only color textures are supported, not bump, opacity, etc.
https://we.tl/3nIiqkemNT
