Archive => Support Archive => Topic started by: Esben Oxholm on January 26, 2017, 08:27:02 AM
Title: Using same bitmap for color and bump. Possible?
Post by: Esben Oxholm on January 26, 2017, 08:27:02 AM
Hi guys.
Whenever I try to use a bitmap as input for both color and bump, the color information dies.
To get the result I'm after I have to copy the bitmap.
Works fine when using a procedural texture.
Is it possible somehow to use the same bitmap for both?
Best,
Title: Re: Using same bitmap for color and bump. Possible?
Post by: guest84672 on January 26, 2017, 11:19:51 AM
Without opening the material graph open the texture tab, and simply drag the texture from the color texture onto bump texture by holding down the CTRL (ALT Mac)  key.
Let us know if that works.
Post by: Esben Oxholm on January 26, 2017, 11:53:20 PM
Quote from: thomasteger on January 26, 2017, 11:19:51 AM
Thanks, Thomas.
By using the method you describe, the color information is kept, but when opening the graph afterwards it shows that is has created a copy of the bitmap. Just like I had to when I did it 'manually'.
This is not a big deal, would just be nice to be able to use the same bitmap input without copying :)
Post by: guest84672 on January 27, 2017, 10:39:52 AM
I agree. I'll talk to Rex and dev about that.
Post by: guest84672 on January 27, 2017, 10:41:37 AM
I just heard that it was already done for KeyShot 7.
Post by: Esben Oxholm on January 28, 2017, 09:18:07 AM
Quote from: thomasteger on January 27, 2017, 10:41:37 AM
Nice! Sounds good  :D
