Technical discussions => General discussion => Topic started by: CoalHedgehog on February 16, 2017, 02:57:03 PM
Title: Turning off part but not animation.
Post by: CoalHedgehog on February 16, 2017, 02:57:03 PM
I have multiple parts linked to a single animation.
I am trying to turn off individual parts so I can see other parts of the animation but Keyshot insists on turning off the animation with the part.
Is there a way around this?
Title: Re: Turning off part but not animation.
Post by: Will Gibbons on February 17, 2017, 07:56:03 AM
Quote from: CoalHedgehog on February 16, 2017, 02:57:03 PM
Hi! It completely depends on how your geometry is structured in the scene tree. If you've applied an animation or linked animation to a part, and then turn that part off... you essentially turn off the animation. Apply the animation to a group (above) the part, and then you can turn off the part while still leaving the animation 'on'.
Post by: CoalHedgehog on February 18, 2017, 09:22:22 AM
If there are 1000 parts linked to one animation, turning off one part means you cannot use the animation anymore?
I'm sure I've not had this problem in the past.  :-\
Post by: HaroldL on February 18, 2017, 01:37:49 PM
Try applying (adding) a Fade animation to the part you want to "turn off".
Post by: Will Gibbons on February 21, 2017, 08:09:30 AM
Quote from: CoalHedgehog on February 18, 2017, 09:22:22 AM
This is again... mostly dependent on your modeling structure. In a CAD application, this is why and how assemblies and subassemblies are taken advantage of in KeyShot.
If you've got everything under a single assembly or on the same level so to speak, you're fairly out of luck I believe.
