Archive => Support Archive => Topic started by: andy.engelkemier on March 15, 2011, 11:04:32 AM
Title: render overbright on Queue using real-time frames
Post by: andy.engelkemier on March 15, 2011, 11:04:32 AM
I queued up 5 renders, nearly all the same.
I told it to process the queue and it came out Way over bright.
I deleted all that's in the queue and without changing the file started rendering using the exact same settings one by one. The downside is I have to be around now for a few hours to make sure and queue the next one manually.
Any idea when this might be fixed? it's pretty much the main reason we purchased Pro.
Title: Re: render overbright on Queue using real-time frames
Post by: guest84672 on March 15, 2011, 11:55:03 AM
And then it worked fine?
Post by: andy.engelkemier on March 15, 2011, 11:58:17 AM
sorry yes. I'm still working on it too. I don't trust the queue now.  :-\
Rendering with the Queue it was overbright, the same file without it, no problems.
Post by: guest84672 on March 15, 2011, 12:02:29 PM
We are testing it and will let you know.
Post by: eric on March 15, 2011, 01:33:16 PM
I never managed to render anything at a decent resolution in "good" quality using the render cue.
Reasons we bought PRO is for rendering a cue overnight and sometimes render single pictures at higher resolutions.
This is not reliable at all. When I come back in the morning my tifs are completely black or white.
It starts to render and stops after a while for some reason.
I have 8GB memory on a dual Quad core Xeon Dell R5400.
When I render these separately it works.
Post by: guest84672 on March 15, 2011, 03:01:44 PM
Using realtime render mode?
Post by: eric on March 15, 2011, 11:42:11 PM
no, i hardly use that. Only for effects
Post by: guest84672 on March 16, 2011, 08:06:23 AM
I am not talking about effects - I am talking about the render mode - offline or realtime?
Post by: eric on March 16, 2011, 01:39:21 PM
Realtime render always works.
I'm talking about hitting the render button.
Isn't this the same as the renderer for the cue?
