1) fix the move/roate widgit when it orthographic view. It becomes so large that I sometimes cannot see my part I am moving.
Also, keep the widget in the same part of the window at all times. It is dificult to orient a part while in a specific view becuase the widgit is not in the window. It makes you zoom
out unitl the widget appears and then you have to re-orient.
2) Have the option to shut off raytracing all together when setting up your scene. Make it similar to working a CAD environment until your ready for ray tracing. This will speed up
workflow and eliminate the annoying fuzzy views every time you change something or re-orient your view.
3) Add a feature to eliminate perfect edges. It makes renderings look fake but I do not like spending hours adding tiny fillets to every edge of an assembly.
Thats all I have for now....I am just being picky anyways. Compared to bunkspeed shot, this program is perfect.
@1) this has been fixed in 2.2.65
@2) Use performance mode - alt P. This will turn off ground shadows, self shadows, ground reflections, and drops the raybounces to 2.
@3) Yes, that is a cool feature. We will look into it.
about #2 ... I noticed that when I am in the Alt+P mode and I save, after re-opening the file it uses these settings for the "none" Alt+P mode ... so, e.g. I got 10 rays and got 2 for shadow and I got the 2 upper most checkboxes checked .. I go to Alt+P and work a little .. then I save and go home .. The next morning I open the file again and it's not in the "low" mode, but it has set the settings to 2 rays and 1 shadow and no checkboxes ...
Is that a bug or intentional ? ;)
That is a bug an has been recorded.
Roger, copy that :)
Quote from: nmeyer on April 27, 2011, 02:20:04 PM
+1
