Share => Materials and Textures => Topic started by: alexjones on July 25, 2017, 07:59:16 AM
Title: Liquid turns black on black reflective ground?!?
Post by: alexjones on July 25, 2017, 07:59:16 AM
Hello ,
I would like to make the liquid the same color as if I put the model on white ground.
Alex
Title: Re: Liquid turns black on black reflective ground?!?
Post by: INNEO_MWo on July 25, 2017, 10:23:16 AM
Did you use a glass material as the ground material? Then try the ground mat with full reflection and use the product lighting present.
Post by: alexjones on July 25, 2017, 12:03:12 PM
Thank you MWo, unfortunately I was not able to get it to work, I am attaching the file, would you mind showing it to me please?
Alex
Post by: guest84672 on July 25, 2017, 12:37:00 PM
Select "Product" lighting mode in the Lighting tab.
Post by: alexjones on July 25, 2017, 02:00:06 PM
It worked ,
Thank you thomasteger
