Hi all,
I have ran into an issue that I'm hoping that you can help me with. I need to not render the backfaces that are facing the camera in this scene. This is a Lidar scan of a cave and I need to exclude the roof of the cave for this render. I found an older post that suggested adding an emissive node in the material graph, I tried that but it didn't work for me.
Keyshot 6.3 Pro for Zbrush is the version I'm using.
Thanks!
If you enable Experimental features (Preferences > Advanced), then you get the Surface Backside Mask utility node in the Material Graph. You can hook this up to the Opacity channel, with maybe a Color Invert in between depending on the normal orientation. This will give you the desired effect.
Something like this rather simplified cave. :)
Thank you, Dries! That was exactly what I needed, worked like a charm. The original thread I found had you insert an emissive node instead of a color invert node.
Thanks again!
I'm using Keyshot 7 and there is no Experimental Features option under the Advanced tab in the preferences window (?)
Quote from: cjwidd on September 18, 2017, 08:34:48 PM
Hi cjwidd.
For some reason the experimental features has been removed from the KS7 UI.
I haven't tried this myself but you should be able to make it appear by going to your KS7Settings.xml file
and setting <experimental_features bool="false"/> to <experimental_features bool="true"/>
Hope it works.
Best,
Quote from: Esben Oxholm on September 19, 2017, 12:10:06 AMI haven't tried this myself but you should be able to make it appear by going to your KS7Settings.xml file
Where is this file located?
Quote from: cjwidd on September 19, 2017, 02:59:28 AM
In Windows it's located in the documents folder as keyshot7.xml
On a MAC as Esben said.
No change, unfortunately
Have you checked the graph?
Maybe the experimental nodes becomes available without the need to check the experimental features checkbox.
Just check the lighting tab on the bottom. If there are more than product and interior mode, than experimental features are available. Also in the material graph in the utilities you'll find the new ray mask as well the backside-surface mask.
The preferences doesn't show the "experimental option"
I definitely appreciate the advice, but I am afraid these features are still not available. I am using an education version, which according to the product comparison, should not make a difference.
Quote from: MWo on September 19, 2017, 09:09:52 AM
This seems like a fairly serious inconvenience, but perhaps I have missed something?
I just tested this with the EDU version and experimental features work perfectly after editing the xml file.
Are you sure you saved the xml file and that you weren't running KeyShot while making the change?
When I try on mac, I get a critical error, that it can't load the file.
Any suggestions on how to avoid this?
KeyShot is closed while editing and saving the file and I don't edit any other lines in the xml.
Esben: Looks like you are using the wrong brackets around the "true" value. It can happen when using TextEdit.
Quote from: DriesV on September 20, 2017, 02:42:50 AM
I'm really not sure what to say, I agree it is unusual. I checked the file in two different text editors - just to be sure - and the bool for experimental features is set to true. The file was edited outside of Keyshot while Keyshot was closed. The 'surface backside mask' utility node does not appear in the material graph drop-down menu. Is there is some other set of conditions (e.g. settings that need to be enabled) that I'm unaware of?
Quote from: hstokholm on September 20, 2017, 03:41:45 AM
Thanks! That was exactly the case. Now it works. Good catch!
The KS7Settings.xml was stored in C:\Users\Public\Documents\KeyShot 7, not in the default Documents folder. I adjusted the file and the experimental features are now available.
