Archive => Support Archive => Topic started by: mutte on September 07, 2017, 08:17:02 AM
Title: Squares in the rendering
Post by: mutte on September 07, 2017, 08:17:02 AM
This is a 4.5mil polygon model from Zbrush, what's the cause of these errors?
Look at the big shapes on the side of the head.
anyone...thanks!
Title: Re: Squares in the rendering
Post by: Esben Oxholm on September 07, 2017, 08:21:26 AM
Hi.
Are you using a translucent material? If so, try increasing the material samples. Solved an issue I had looking similar to this.
Post by: mutte on September 07, 2017, 11:02:31 AM
Hi Esben, this seems to be working!!! thanks!
Post by: Esben Oxholm on September 07, 2017, 11:38:49 AM
Quote from: mutte on September 07, 2017, 11:02:31 AM
Great! Glad to hear :)
Post by: mutte on September 07, 2017, 12:11:37 PM
Nope, gotta take my words back it happen'd again. Strange on a other subdiv from Zbrush it doesn't happen.
Any other ideas.... Thanks
Same happens with a flat material....
Post by: Will Gibbons on September 08, 2017, 11:58:33 AM
I could be wrong, but try right-clicking and choosing 'edit geometry'. Then, choose 'edit normals'. Then with the mesh selected click 'calculate normals'. Save and close the geometry editor and see how it looks.
Post by: mutte on September 11, 2017, 01:27:29 AM
Hi will, I've tried it and it did not solve the problem
Post by: mutte on September 11, 2017, 01:57:15 AM
Ok it has something to do with the topology and the sharpness of details, if I retop the head and tone the details down it gets better.
But it's still variable depending on the HDR map in the enviroment.....
