Technical discussions => General discussion => Topic started by: Robb63 on March 06, 2018, 12:55:53 PM
Title: How to do something more like "Viewsets"
Post by: Robb63 on March 06, 2018, 12:55:53 PM
I used to love working with Viewsets in Keyshot 6, and found them very intuitive and a real time saver.
In KS 7 I am constantly saving a camera, with the environment, but then I rotate the environment while setting up my next camera, and now I've changed the environment for the previous camera.
Can I tie the camera and saved environment together so that I can still experiment with my environment lighting, but still get back to a saved environment (rotation, brightness, height, etc...) if I don't find a better version while tweaking.
Basically I guess I'm asking is there something that works the same as "Saved Viewsets" used to work in KS6?
Title: Re: How to do something more like "Viewsets"
Post by: mattjgerard on March 06, 2018, 01:47:30 PM
I'm assuming that you've tried using Studios and that for some reason its not working for you? I have done the same thing with a large model of say an offset web printer that might have half a dozen of our products on it. I set up a studio for each product around the machine, they are sensors, so they are mostly small. Then I position a camera for each view, assign it to the proper studio for the product its looking at. Then, since lighting is never the same, I create one environment that works for the first studio/camera angle. Then I move to the second studio that has a different camera assigned to it. If the current Environment doesn't work for that shot, I duplicate the environment, assign the new one to the current studio and start playing around. I'll end up with 2-3 "Test" environments before I pick one I like. Then move to studio 3. If neither of those environments from studio 1 or 2 work, I'll duplicate it again, and play with it again.
Clicking on the studio switches quickly between the camera and environment. Its actually pretty slick. I started on KS at the end of version 6, and just when I figured out viewsets and the other stuff they turned it all into studios and model sets. Which I now use every day.
Hope this helps.
Post by: Will Gibbons on March 07, 2018, 11:25:33 AM
Quote from: Robb63 on March 06, 2018, 12:55:53 PM
I just made a video quick-tip showing how to do this. It only takes about 20 seconds. Here you go: https://www.youtube.com/watch?v=BFjXL4tZyp4 (https://www.youtube.com/watch?v=BFjXL4tZyp4)
Post by: DMerz III on March 07, 2018, 01:03:59 PM
Studios is so much better! It is like viewsets but with waaaay more control.
Post by: Robb63 on March 07, 2018, 01:14:52 PM
Thanks for making that video Will! That does a good job of explaining it.
I tried using Studios when KS7 first came out, but I didn't quite get what was going on. I realized after reading some of yesterdays replies to my question that I've just been closing the "Studios" window whenever I open Keyshot and not using it at all.
Now I get it.
Thanks to all!!!
