Technical discussions => General discussion => Topic started by: jhiker on April 17, 2018, 01:44:20 AM
Title: Glass colour confusion
Post by: jhiker on April 17, 2018, 01:44:20 AM
A quick question..
I allocated a 'solid yellow' glass' material to a ground plane - why does it look red?
Keyshot v7.3
Thanks,
Jeff
Title: Re: Glass colour confusion
Post by: Will Gibbons on April 23, 2018, 06:47:05 AM
I believe it has to do with two factors.
1. Transparency distance. The lower you set this the darker and more saturated the material will get.
2. Plane thickness. If it's a single plane... you should just use basic glass material and set your color. The solid glass needs thickness to work accurately.
