Other => Wish List => Topic started by: mattjgerard on July 16, 2018, 10:07:39 AM
Title: Renaming tweaks
Post by: mattjgerard on July 16, 2018, 10:07:39 AM
Couple instances of things not operating consitantly when renaming stuff-
1) Renaming a Studio set requires a double click on the name of the studio
2) Renaming a Model set requires a double click on the model set name, unless the model set isn't selected, then it requires a single click to activate, pause, double click ( would be nice to be able to rename the model set without having to activate it first)
3) Renaming a Camera in the Project-Camera tab requires a single click (double click does nothing) Would be nice to make this a double click like #1 and #2
4) Can't rename a camera in the Project-Scene tab. Would be nice to rename a camera here with a double click. Double click switches to that camera, should be a single click to switch to that camera.
5) Double clicking a material in the library does nothing, have to right click -"Rename" to change the name. Single clicking a material does nothing as well.
Basically, a double click should be for renaming, a single click should be a switch-to/activate function.
Small seemingly insignificant, but helps with the continuity and user experience.
Title: Re: Renaming tweaks
Post by: Will Gibbons on July 18, 2018, 10:40:53 AM
Not insignificant at all. This drives me nuts. Thanks for compiling a list. I'll share it and see if we can get it sorted.
