I am new to using animation in Keyshot but I was trying to fade in an object, do some stuff, then fade the object back out. Even tried just fade in and fade out. The two bars show up in the animation timeline. When I have just the fade from say 0 to 1 second it works just fine. Then I have it fade the same object out from 100% to 0% from 1 second to 2 and it doesn't work.
If I have another object in the scene and I want to fade that one out half way through it breaks the fade in.
Any ideas on what I'm doing wrong??
Which version of KeyShot do you use currently?
7.3 pro.
Basically, I want to fade an object in, then fade it out and have a new object fade in and replace the first one.
Hello wayneheim.
IMHO this scene should do the animation right. (I would do these steps this way)
Hope that helps
Thank you. I'll take a look.
