Other => Wish List => Topic started by: elliasp on August 02, 2011, 02:08:28 AM
Title: More options in material creation (see exemples below...)
Post by: elliasp on August 02, 2011, 02:08:28 AM
Sometimes, to find the good position of a label or the good material bump are very difficult to find, it's a lot of work on photoshop, a lot of tests in Keyshot to find the good result...
I had some ideas, what do you think ?...
F
Title: Re: More options in material creation (see exemples below...)
Post by: guest84672 on August 02, 2011, 06:00:55 AM
You can assign more than one label to a material today. You can assign as many as you want, and even reorder them.
Post by: Speedster on August 02, 2011, 06:42:59 AM
Just be sure that, if you need to use the same decal more than once, that you assign different names to them.  Like 1-decal, 2-decal, and so forth.
Post by: elliasp on August 02, 2011, 11:27:06 AM
Oh... sorry, I missed that...
Is there an exemple (about stickers) in webminars ?...
Post by: guest84672 on August 02, 2011, 12:29:07 PM
Not sure ... but just keep adding the individual labels under the label tab.
Post by: elliasp on August 03, 2011, 12:23:30 AM
OK I got it now  :)
thanks !
Post by: guest84672 on August 03, 2011, 10:06:51 AM
Ah yes - that's it!! If you want the fragile label on the same surface as another label, you can do this by simply placing it over the other label, and then change the order if needed.
Post by: elliasp on August 03, 2011, 10:58:49 AM
Thank you Thomas  :)
