Technical discussions => General discussion => Topic started by: samia.hossain@teknion.com on August 20, 2018, 02:10:52 PM
Title: Cannot Import larger .dwg files
Post by: samia.hossain@teknion.com on August 20, 2018, 02:10:52 PM
hi All,
I am new to Keyshot. I want to import an AutoCAD 3D file to KeyShot. The window says, "importing ****.dwg" and stays that way. Nothing happens. What should I do?
The .dwg file is 9MB.
Thanks in advance,
Samia.
Title: Re: Cannot Import larger .dwg files
Post by: mattjgerard on August 21, 2018, 05:26:32 AM
can you open the dwg in any other app, just to make sure the file isn't corrupted?
Post by: samia.hossain@teknion.com on August 21, 2018, 08:40:49 AM
Hi mattjgerard,
Thanks for your comment.
Quote from: mattjgerard on August 21, 2018, 05:26:32 AM
cannot open in SketchUp too. How to prep the .dwg file?
Post by: mattjgerard on August 21, 2018, 08:47:52 AM
https://www.autodesk.com/products/dwg/viewers
choose one of these apps to see if they can open your file. It sounds like it might be corrupted, in which case you will have to go back to the source of the file and see if you can get another exported file, maybe try another format.
