Some tests with new KS8 displacement...
Awesome examples :-)
Those last ones look like JSplacment examples :) I just found that app and its awesomely fun! This is one I knocked up real quick last night when I needed to burn up 15 minutes before heading home-
My! These are some cool experiments. Nice exploration.
Yes, most of those were done using maps from JSPlacement https://windmillart.net/?p=jsplacement (https://windmillart.net/?p=jsplacement). Great little app and it's free.
Hi
I have a problem with displacement. The result is pixelated and not clear. What is the right way to go about it?
Quote from: Finema on October 06, 2018, 06:00:08 AM
Hi
Increase the number of triangles allowed and possibly reduce the mesh resolution in the displacement shader.
Thank you.
But even if the number of triangles is increased to 20 million, the result is not clear
Quote from: Finema on October 06, 2018, 11:12:27 PM
Thank you.
And did decrease the value of the resolution?
yes
Can you share your scene with beta@luxion.com then we can take a look at it? We have some improvements to displacement mapping coming in 8.1.
I sent my scene
Here a screenshot you can see that the circular shape is not clear (resoluion 0,01 et 20 M triangles
Love the engraved look on the top one there! I'm in a process to pull of a similar look so that's gonna be a reference image for the process :)
Quote from: Finema on October 08, 2018, 12:41:41 AM
Is the displacement map 8 bit? Smoother results will be attained with 16 bit (PNG) and 32 bit (EXR) textures. Also, take note of the triangle count in the HUD in the viewport. Does the count increase when you increase the Max Triangles count to 20 million in the Displace node properties? Keep increasing the Max Triangles count until you see an increase in the HUD (for the initial increase, try setting a value at least double the triangle count shown in the HUD). Try setting the Resolution value to .001.
Cheers,
Eric
Quote from: Magnus Skogsfjord on October 08, 2018, 04:03:43 AM
I used the same greyscale map for the displacement – which is set to a small amount – and also for the roughness, which helps sell it. I was pretty pleased with the result! And in answer to the guy above, yes your displacement maps need to be very high resolution and very high bit depth. And don't be afraid to take the resolution down to really low values – like 0.00001. Of course, sometimes it's just easier to model the geometry if it's a relatively simple shape.
