Technical discussions => General discussion => Topic started by: Eric Summers on November 07, 2018, 07:52:14 AM
Title: Migration assistant
Post by: Eric Summers on November 07, 2018, 07:52:14 AM
I could've sworn I saw a thread about this, but I searched to no avail. Is it possible to run the migration assistant after KS8 is installed? KS8 was installed on a machine by IT so I didn't get the chance to transfer my settings from 7. I'd prefer to not have to re-install just to run the assistant if possible.
Title: Re: Migration assistant
Post by: Rex on November 07, 2018, 09:43:34 AM
Delete your XML file with KeyShot closed and the Migration Assistant will be launched when opening the app.
Post by: Eric Summers on November 07, 2018, 11:11:21 AM
Thanks Rex!
At first it didn't work, turns out it was the XML file in the Public Documents folder not in the "my username" Documents folder. I'm not used to dealing with the Public folders. Would changing it to my documents folder require a re-install?
Post by: Rex on November 07, 2018, 11:52:29 AM
Yes, you will have to run the full installer as this path is defined upon installation by selecting between install just for me vs for everyone.
Post by: Eric Summers on November 07, 2018, 12:36:27 PM
Got it. Thanks again Rex.  :)
