Technical discussions => General discussion => Topic started by: PhilippeV8 on September 15, 2011, 06:37:02 AM
Title: realtime render - vs time limit realtime render
Post by: PhilippeV8 on September 15, 2011, 06:37:02 AM
Got a question.
If I have a scene and I let it render with:
-the realtime renderer and after 1h20m I hit "stop".
-the realtime renderer set to stop after 4800 seconds.
Is it so that this should give me the exact same result ?  Or at least should we expect to have the same result, or is there a difference ... cuz I ain't getting the same result ...
Without setting a timer limit, I can't put realtime renders in the Q and leave it overnight ... so I did 1 render during the day and looked how long I had to let it sit for it to be ok.  I came to conclusion that 1h and 20min was OK .. So I put all the lot in a Q with 4800 seconds limit and leave over night.  This morning, all renders I had finished were grainy.
So my conclusion is ... it renders better with no time limit set !!
Cuz I did a test just now and rendered it with 6000 seconds limit ... still grainy .. now it is rendering without limit and after less than 1h it's looking A LOT better already !!
Is this expected behaviour ??
Title: Re: realtime render - vs time limit realtime render
Post by: PhilippeV8 on September 23, 2011, 02:39:18 PM
no word on this ?
Post by: EGON on September 23, 2011, 03:00:12 PM
I use realtime all the time. The longer it renders the better.
Post by: m2tts on September 23, 2011, 03:46:41 PM
I have not had good luck with Real-Time. It's great for clear objects that get dark splotches using the regular engine; but some areas on materials with roughness and lots of shadow seem to never not be grainy no matter how long I let it bake.
As for time or frames, I say use frames. This is a quantity that will be reached no matter what other things your machine may be doing other than rendering. Frames you can set for any number of images of a scene you want and will get consistent results.
Post by: PhilippeV8 on September 27, 2011, 10:34:06 PM
Still I'm hoping for a word from the KS team on this issue ... ;)
Post by: guest84672 on September 28, 2011, 06:10:45 AM
What issue? The "graininess"? If so, you may need to increase the samples for the material. Turn on the advanced settings in the preferences, then edit the material, and change the samples to a higher number.
Post by: PhilippeV8 on September 28, 2011, 07:51:17 AM
No, the issue is that there is difference between "1 minute realtime render with manual stop" and "1 minute realtime render with time limit stop" ... seems like the timer used for that proces uses up CPU speed which makes it render slower or something ???
Is this normal ?
Post by: guest84672 on September 28, 2011, 08:24:48 AM
I'm afraid I don't understand what you mean ...
Post by: Chad Holton on September 28, 2011, 08:35:01 AM
Hi Philippe,
Are the resolutions the same between the two you are comparing?
Post by: PhilippeV8 on September 28, 2011, 11:28:52 PM
Yes they are.  Same file, same settings, same everything.  Only thing I change is toggle to time on the quality tab of the realtime render.
So I set no time limit and render for 1 minute and stop manualy vs. I set a time limit of 1 minute.  These 2 renders are NOT the same !  Seems as the render with the time limit set is less "done" than the one I stop manualy.
As I said, I got a scene which I set up in the Q with realtime render and a time limit of 1.5h.
If I render the exact same scene and setup manualy, after less than 1h, the quality is already WAY better then the end result I got on the previous render.
I hope it's clear now what my problem is ;)
Post by: guest84672 on September 29, 2011, 05:26:39 AM
Ok understand now. We will take a look.
Post by: Chad Holton on September 29, 2011, 07:18:56 AM
Hi Philippe,
I have been testing this one and can't reproduce. Are you able to send a package file of the scene and/or the renderings showing the difference? If so, please send it to support@luxion.com, so I can look into it more.
Thanks,
Chad
Post by: PhilippeV8 on September 29, 2011, 07:51:00 AM
I made an ksp, but it's 191MB ...  :-\
Post by: Chad Holton on September 29, 2011, 08:17:14 AM
No problem - do you have an upload link you can send it to? If not, send me an email: chad@luxion.com and I will set you up with a link.
Thanks,
Chad
