I would love to see a wire frame material so you could render stuff like this:
yes!! good idea!
Antoine
Problem is that Keyshot sees things as triangles not quads (like most rendering software does). Hypershot used to have a wireframe material I used to do things similar to that, but again this is getting into areas that are outside the core of the application (I think). Funnily enough, this kind of thing is easy to do in SolidWorks with the built in PhotoView software and combos of OpenGL renders of the wireframe using the same camera view. If Keyshot to utilise the SolidWorks cameras they you could just combine the two images...
KeyShot has the wireframe material as well.
