Hi guys,
Can anyone let me know a set of optimum computer specs for running Keyshot; I'm not interested in the min. spec's, but ones that would mean i'd have little problem rendering out products with quite a bit of exterior detail ie. multiple glass components stacked on top of each other in combination with texture bumpmaps?
I only ask as I've been having a few issues recently with Keyshot taking forever to output renders & crashing along the way and I've just figured out that it was the glass and bumpmaps mentioned above that were causing the issues and I wondered if maybe my computer's not beef enough?
Any suggestions would be most welcome,
Thanks loads, really appreciate your help on this.
Jay.
I think that's hard to say ... cuz as is always the case with computers .. there ain't not upper limit .. there's only an upper limit in your wallet.
Maybe I should re-phrase my question,
out of interest, what spec computers are people using with Keyshot and do they feel satisfied with its performance?
Maybe then I can compare the spec's of my work computer and see if they are massively under what you guys are using?
Thanks for any info.
Jay.
http://keyshot.com/forum/index.php?topic=1425.0
does this help ?
did you try the benchmark on your pc ?
