Other => Wish List => Topic started by: Eugen Fetsch on September 23, 2020, 05:18:43 AM
Title: Background Brightness
Post by: Eugen Fetsch on September 23, 2020, 05:18:43 AM
It would be great ho have the possibility to animate the brightness of the background.
Title: Re: Background Brightness
Post by: INNEO_MWo on September 25, 2020, 10:00:35 PM
Hello Eugen.
Would it be helpful if you use a sphere with an emissive material as a background? Then you could use a number or color animation for the intense parameter. But don't forget to use the experimental feature ray mask in the opacity channel with the seen in reflection option.
Hope that makes sense
Post by: Eugen Fetsch on September 28, 2020, 01:50:35 AM
Hey Marco,
that makes a lot of sence and it works, but it doubles the render time per frame.
Thank you very much for the workaround!
Post by: Eugen Fetsch on September 28, 2020, 01:55:02 AM
Edit: Threre are some other issues with the ground shadows. So it doesn't work for all the scenes.
Post by: INNEO_MWo on September 29, 2020, 12:56:28 AM
So there should be a script solution - if I remember right, the brightness parameter can be edited via script - BUT - that makes the entire workflow slightly complicated, cause the script has to push every frame into the queue.
Post by: Eugen Fetsch on September 29, 2020, 04:50:12 AM
I see. Thanks Marco. Hope Luxion will implement it some day.
Post by: andy.engelkemier on September 29, 2020, 12:33:20 PM
This also doesn't work with GPU render. So if you're using GPU render then it will increase your time by much more than double.
