Any feedback will be much appreciated
Hi AK! Welcome to the forum, the main improvement where you could start is adding surface imperfections to your large flat area's such as walls, ceiling, ... at the moment you just have a texture but you want add more variation in glossiness, bump, ... This will give Keyshot a lot more data to work with and will make everything look a lot less 'flat'. Another thing you might want to work on is adding a lot more props. Currently your geometry is very basic and blocky. If this is the design you are going for you should spend some time adding 'clutter'. Reference images are great for this!
Regardless, excellent try! You'll get better with every interior you do!
