Archive => Support Archive => Topic started by: ukindler on December 06, 2011, 10:24:00 PM
Title: Keyshot 3 Bugreports (decimal separator issue)
Post by: ukindler on December 06, 2011, 10:24:00 PM
I just installed the latest keyshot update 3.0.82. Here are the bugs I discovered so far:
1. Decimal separator issue
In all value fields (like in material textures panel) the values are printed with a comma as decimal separator. That means, if I move the X-Scale slider I can see the value 1,2 but if I enter 1,3 into the value field nothing happens. But if I enter 1.3 into the value field, the software updates the texture scaling. This happens for all value fields so it seems to be a global decimal separator issue. Alle values are printed with comma separator but only accept user input with point separator.
2. Keyshot 2 texture loading issue
The texture loading issue from my last bugreport still exists - that means texture parameters from KeyShot2 files are not loaded properly so textures sometimes look distored and I need to manually update the Type, Scaling and texture shift.
Uwe
