Archive => Support Archive => Topic started by: ukindler on December 14, 2011, 05:36:08 AM
Title: KS3 Image Settings Resolution Problem
Post by: ukindler on December 14, 2011, 05:36:08 AM
I found another small bug in KS3. It is not possible to set the width of the realtime window in Project -> Settings -> Image Settings to a value smaller than 325. If I enter a value like 137 into this field, it automatically switches back to 325. This problem is caused by the bottom toolbar below the realtime window. If I undock the toolbar an put in on the left or right side of the window, than I can select a smaller width than 325 but now the minimum height is limited. So the only solution so far is to completely undock the toolbar.
Uwe
Title: Re: KS3 Image Settings Resolution Problem
Post by: KeyShot on December 15, 2011, 05:42:10 PM
Thanks. We will fix that. You can still resize the window to get a smaller output window.
