Technical discussions => General discussion => Topic started by: Caitcuta on March 02, 2012, 12:11:17 AM
Title: Large File Size
Post by: Caitcuta on March 02, 2012, 12:11:17 AM
Hi, I'm rendering a few images which are going to be used in a brochure and have just been told the first copies I sent weren't high enough quality. Apparently he's after something 300DPI and around 2mb in size, my current renders are about 150kb max and I have no idea about DPI...
What are the best settings for producing high quality images? I'm using Keyshot Standard. It's a small brochure so the photos won't be massive.
Title: Re: Large File Size
Post by: guest84672 on March 02, 2012, 06:51:56 AM
You can render up to 4.1 megapixels in size. At 300dpi, this is about the size of half a page. To get to the desired resolution multiply the height and width in inches respectively with 300. That gives you the dimension of your rendering.
Post by: jhiker on March 02, 2012, 07:28:29 AM
Keyshot has several presets under the 'Render' tab.
I occasionally supply our graphic design people with pictures for our product brochures - they're usually happy with something like 1200x900 @300dpi, which happens to be one of  the presets. This will give you a print size of 4"x3" (at 300dpi).
