Share => Materials and Textures => Topic started by: 78finn on May 17, 2010, 11:42:06 PM
Title: Light imiting materials? How to...?
Post by: 78finn on May 17, 2010, 11:42:06 PM
Hi there,
Just trailing a KeyShot and very impressed so far.
One thing I have not been able to find so far - light limiting materials? Specifically LED's small lights for electronics and devices...maybe car headlamps etc.
Is this possible in KeyShot, if so what type of material/material settings should I be using to get a realistic glow effect?
Any help would be appreciated.
Title: Re: Light imiting materials? How to...?
Post by: guest84672 on May 18, 2010, 06:04:47 AM
Either use the flat material, or the general material and make the ambient color bright. Version 2 will have an actual light emitting material.
Also, to see the effect of "color bleeding", please make sure to turn on "detailed indirect illumination" in the settings tab!
Thomas
Post by: tug on August 22, 2010, 03:41:48 AM
To create lighting effects in keyshot it's easy, you must prepare your model with several "lighting's surfaces" where you can apply "emissive material's type". Once done this, modify color, intensity, if you want to be visible for eyes or reflections is accurately easy.
Try a little and be sure you'll get surprise results!!!
rgds
Post by: JasonIftakhar on October 20, 2010, 12:34:04 PM
Hi Guys just downloaded the new version of Keyshot and cannot seem to find Translucent or light emmiting materials in there??????
I turned on advanced options in the preferences tab.
anyone help???
Post by: guest84672 on October 20, 2010, 03:50:01 PM
Did you download 2.1? Where are you looking?
