The best result was using UV but still see some bad result see the picture.
Did you attach a picture? Didn't see it.
I send new image size
Marc
http://img203.imageshack.us/img203/236/10100104500015test.jpg
Did you try box mapping?
Can you send a file to support@luxion.com? We will take a look at it.
Henrik
Thomas
This is the image with the box mapping, still not very good.
Marc
http://img6.imageshack.us/img6/4480/10100104500019test1.jpg
Are you sure that this is with box mapping? I am looking at the stretched texture, and this appears to be more of a projection map ...
For the image
I get the same effect when mapping a texture to a dome shape in solidworks.
I found that mapping along a plain makes the texture slightly distorted.
But overall it gives a better result than UV.
We are working on a fix for this. Will come in the next update.
