Hi, I've got this while rendering paint materials. Any idea? Thanks.
(http://img855.imageshack.us/img855/9045/issueg.jpg)
What is the model format?
Could you possibly send the model to support@luxion.com?
It is an OBJ, exported from 3ds max. I'll try other formats, hopefully it will fix the problem, if not i will send you the OBJ file.
I've solved the problem, i had to collapse the modifier stack in 3ds max to an editable mesh. Before I just simply exported the editable poly object with a turbosmooth modifier.
