Gallery => Amazing Shots => Topic started by: Gavrik on February 26, 2013, 05:19:49 AM
Title: Just an image done in KS4
Post by: Gavrik on February 26, 2013, 05:19:49 AM
dual-layer material trick
Title: Re: Just an image done in KS4
Post by: snooky_rock on March 01, 2013, 08:45:18 PM
what is that ?!
Post by: Gavrik on March 03, 2013, 10:24:47 AM
This is my test try to make patina. I used 2 layers of 1 mm from each other. Bottom layer material is gold. For the top layer, I used the transparency map. Maybe someone knows a better way to do this?
Post by: fario on March 03, 2013, 01:43:56 PM
I think your picture is very well done.
Bravo!
it's post-production with Photoshop?
Antoine
Post by: Speedster on March 03, 2013, 01:47:45 PM
You might want to test layers more like 0.25 mm or less?  Then, if seen on an angle, there would be less shadow distortion.
Post by: Gavrik on March 03, 2013, 03:55:34 PM
Image in the first post is render without any post-production. Two pictures in second post - photos. Trick with two layers nice works when I have simple surfaces. But if I have a lot of complex surfaces? I will need to duplicate each. Not very convenient.
It would be better to have 2 layer material.
Post by: Speedster on March 03, 2013, 05:30:29 PM
Don't forget- Each layer has two surfaces, and you can UV map each side of each layer.  2 layers = 4 surfaces.
