Technical discussions => General discussion => Topic started by: norge on March 15, 2013, 01:34:35 PM
Title: Live Linking & Solidworks
Post by: norge on March 15, 2013, 01:34:35 PM
I have Solidworks2013 and i want use a Live Linking - i have installed a plug-in for SW and when a press a Keyshot update button (during drawing in SW)  there are not any changes in KS?
In KS Live Linking is enabled.  What is wrong?
regards
Title: Re: Live Linking & Solidworks
Post by: guest84672 on March 15, 2013, 04:11:09 PM
You need to make that you parts and assemblies are regenerated. Depending on the changes you may need to select the parts you changed inside SW and then hit Update. This will send them to KeyShot, and update the existing parts that are currently in session.
Post by: norge on March 16, 2013, 10:27:38 AM
Still nothing,
- drawing in SW (2013) - ok!,
- hit KS (render) button in SW and open KS - ok!
- change drawing in SW and hit update button  - no change in KS session!
any ideas?
Post by: guest84672 on March 18, 2013, 06:54:24 AM
what kind of changes are you making? Also, please try and select the parts you changed, and then click the "Update" button.
Thanks.
Post by: norge on March 26, 2013, 05:24:16 AM
hello again,
"what kind of changes are you making?" - for example i draw a square and make a solid ,then i hit render and open KS then i back to SW and in a center of square i make hole - hit update button and nothing changes in KS,
i tried - i think all : update all, part, after before : save, rebuild, still nothing !!
again any ideas?
regards
