Hi
I cannot get the ProE plug-in (new 2.2) to work on my ProE 5.0 / Creo elements M170 runing 64bit
I'm getting an application unknown error and it does not start - see attachment for error
This is not working on my production setup and just to be sure that the ProE installation is ok, I have made
a new clean ProE installation on a clean Windows7 but that does not work either
Any ideas?
Best regards
NielsC
Try installing/updating the components from Visual C++(2005,2008,2010). We are working on improving this.
Assume this is the Visual Basic API or Pro/Toolkit that are part of ProE installation????
It was installed on my production installation but not on the clean installation - tried to install
but did not helt
Just checking the installation files of the plug-in: the file keyshot4_proe5_plugin.dll seems relatively old.
It's is dated 23-05-2013 13.07 size 15.1MB
Could this be too old??
The error message below indicates that there is a mismatch on the proe version as my
application for Edrawings show the version 29 but for Keyshot is is unknown
Application 0: eDrawings
Exec path: C:\PTC\PROE5_64\x86e_win64\obj\proeconnector.dll
Text path: R:\SETTINGS\eDrawings2013\eDrawingsProE
Version 29 - 2010370
Application is running.
Application 1: KeyShot4
Exec path: C:\PTC\KeyShot4\Plugins\ProEngineer5.064bit\keyshot4_proe5_plugin.dll
Text path: C:\PTC\KeyShot4\Plugins\ProEngineer5.064bit
Version unknown
Application is not running.
BR NielsC
Tried to install Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.60610 as the attempt
to install version 2010 gave the message that newer files were present
Still no luck
Hey Nielsc,
had the same Problem a month ago.
I ask the IT department to reinstall Keyshot and the plugin. It was realy importent that they did it with the Administrator Account
Also we installed the following runtime library:
http://download.microsoft.com/download/8/B/4/8B42259F-5D70-43F4-AC2E-4B208FD8D66A/vcredist_x64.EXE (http://download.microsoft.com/download/8/B/4/8B42259F-5D70-43F4-AC2E-4B208FD8D66A/vcredist_x64.EXE)
Best Regards and good luck!
Chrishan
:D :D
Thank you that worked.
It must be the Run As Administrator that did the job as i have tried to install
the additional files before
Don' know if wrong but i had to add the menu points manually
NielsC
I've tried it all, and it's still not working for me.
Installed VisualC++ and .NET
Reinstalled both keyshot and plug-in as administrator.
Does anybody know what could be wrong?
Maybe you have some screenshots?
