Has the functionality of this right click command changed in 4.2? Does not seem to fit the object?
Also in the project position tab, 4.1 under rotation would jump 45 deg each step.. now seems to do 1 deg at a time?
It should still fit the object - we will test.
Yes, we made the change after multiple requests for fine-tuning the rotation. You can quickly rotate an object by 45ยบ using the move tool and holding down the shift key.
Thanks Thomas
can someone else please text this to make sure I am not going mad!
You're not going mad - bug has been found and issued (by Thomas). Thanks for the heads up.
cool .. Thanks Chad
