Gallery => Amazing Shots => Topic started by: ajilopez on April 05, 2014, 07:00:26 AM
Title: TRD 86
Post by: ajilopez on April 05, 2014, 07:00:26 AM
Finally, after a year of stop and go modelling, I've finally finished transforming this regular 86 to a TRD 86. Just a test render for Toyota Alabang here in the Philippines. It's sporting an all black TE37 Tokyo Time Attack Progressive rims.
Title: Re: TRD 86
Post by: edwardo on April 05, 2014, 07:13:00 AM
You need to re-light this entirely I think. I can't see whats going on at all. It'll be worth it... if youv spent so long modding the car, its worth showing it off to the best standard possible.
Push it...... work it.....ooh yea
Title: Re: TRD 86
Post by: ajilopez on April 05, 2014, 08:52:42 AM
Oh darn it! I had my Nvidia digital vibrance set to 100 while I rendered this. Everything was bright then. Anyway I'll go work on this again soon. Thanks!
Carlos
Title: Re: TRD 86
Post by: edwardo on April 05, 2014, 09:02:35 AM
also, is your HDRI quite low resolution? the reflection on the front wing/wheel arch looks quite jaggy. This is often down to low tessellation on your model, but it looks ok here (wheel arches look nice and smooth), so I'm guessing your HDRI may be quite low res (2000x1000 maybe?)
hope this helps
Ed
Title: Re: TRD 86
Post by: ajilopez on April 05, 2014, 09:12:50 AM
@ed
actually, this is a full 3d scene. no hdri used. the environment is pitch black, then used planes set to area light diffuse as a light source.
cheers
Title: Re: TRD 86
Post by: edwardo on April 05, 2014, 09:19:09 AM
oh, ok  :)
Title: Re: TRD 86
Post by: ajilopez on April 05, 2014, 10:53:49 PM
@ed it was supposed to look something like this XD
Title: Re: TRD 86
Post by: Josh3D on April 07, 2014, 06:32:06 AM
Still looks like the image is low-res. Highlights could be improved to pick up the curves of the car. Check out Tim Feher's 'Best Practice for Automotive Renderings' (https://www.keyshot.com/learning/webinars/) in our webinars.
This one (http://www.importmonster.com.au/shop/images/resizedimage19201081-trdgallery02_3.jpg?osCsid=34ea19368022510975216ea1aa10905d) is a good rendered-looking image. You can see how all the detail is picked up, even in the grill.
This one (http://farm8.staticflickr.com/7020/6447020103_c7fa229e54_b.jpg) is a more realistic render and still you get a good feel for the curves and detail.
